Old 20-12-2006, 18:37
Old 20-12-2006, 19:30
Check your throttle cable isnt too tight.
check that you do not have a vaccum leak on one of your pipes after you reassembled it.
Check that the butterfly inside the throttle body is shutting fully
Check the thottle lever return stops
Old 20-12-2006, 20:51
mr2sc89 mr2sc89 is offline
yeah chek for an air leek, and also it wouldt be any harm if u had a timin gun and reset the timing. under the air box is a connector with cables, one has bout five, there is a large grey black one, a signal cable, check for corrosion, and on all of the cables. had similar problem with starting and then not starting, and idle problems, rewired those n now shes sweet! similar problem was also a misfire, bad earth on pluglead? few ideas. hope ye solve it?
