Old 29-12-2006, 23:57
smoker's Avatar
smoker smoker is offline
Thanks for replies . My plugs are BCPR7E's gapped to 0.9mm...they have only done about 3k miles but I will change them anyway. The pop off valve is plugged and I can't see any other obvious boost leaks
All i can think off is the intercooler is leaking when it gets pressurised but it looks ok. Could the fuel pump be not supplying enough fuel ?
Old 30-12-2006, 00:18
wacomuk's Avatar
wacomuk wacomuk is offline
could be or fuel reg is stuck, to much pressure or not enough maybe
you can check for boost leaks with a gas blow lamp. have the car running turn on the gas (don't light it) blow the gas on to and around anything that may be a boost leak. the revs will pick up if the gas is sucked in through a leak
check inside the dizzy cap
Old 30-12-2006, 00:30
adzs12's Avatar
adzs12 adzs12 is offline
Forum Regular
Thats a good tip that is
Old 30-12-2006, 00:35
Very good tip. i like that too
HT leads failing under load could be another possibility, Or your ignition timing could be out
Old 30-12-2006, 01:32
sounds like a boost leak, really lean at idle and seriously rich on boost
Old 11-01-2007, 14:49
smoker's Avatar
Thanks for the replies . I tryed checking for leaks with the gas lamp but that didnt show anything up. Engine runs fine on normal boost so I figure the fuel pump isn't supplying enough fuel...I did a check and it pumps about a litre pop bottle full in 30 seconds . ..I guess my next move is to fit the walbro 255 fuel pump in case mine is getting tired and starving the engine of fuel at high boost
Old 11-01-2007, 14:56
adzs12's Avatar
Forum Regular
still sounds like a boost leak to me
