I found a excel that mention 200 SX se 1987, the 5Th ratio is different that on mk2 ratios said before:
1st 3.321 2nd 1.902 3rd 1.308 4th 1.000 5th 0.838 instead of 5th 0.759:1 Final gear ratio 4.111 Perhaps it's an american difference. http://www.mediafire.com/?8ctjqadnujd What do you think about it? |
The final ratio is in the rear diff. Changing this would have the best effect.
Manual - 3.7 Auto - 3.9 FJ20 - 4.11
3.9? Are you sure? i mean all sources tell 4.11 and 4.111 on R200 Ca18et
Manual CA18ET is 3.7
Auto CA18ET is 3.9 FJ20 is 4.111 Maybe the Euro 8 spark cars had different diffs
Would an ca s13 gearbox fit my mk1 s12 if i use my mk1 bellhousing?Or are the propshafts or selectors in different positions, I need to know weather to keep it as a spare or not
the s13 boxes are the same design but different length (longer) than a mk2 silvia box, the mk1 box is a lot different and a slightly different length too. Changing to and s13 box does mean a wider range of boxes available and possibility of a close ratio version if you use the s14 box with the s13 bell housing. Im 90% sure that the mk2 silvia box bellhousing is teh same as the s13 tho.
Did you have to change the length of the prop when using the S14 box, and was the shift in the same place? Was the gearbox mount transferrable?
I'm thinking of trying to find an S14 box. I already have 2 S12's and an S13 box, but if the prop length is the same as S14 then i'll use the S13 box till a decent S14 box comes up.
