Old 22-01-2007, 17:07
RichardK's Avatar
RichardK RichardK is offline
Forum Administrator
does anybody make standard diameter discs that are thicker?
Old 22-01-2007, 17:12
Nope but I would suggesting getting the discs I linked to above which are 296x30, and use R33 calipers.
Of course if you converted to S13 hubs and coilovers for the front this opens up a new world of brake and suspension choices.
Old 22-01-2007, 17:20
RichardK's Avatar
Forum Administrator
R33 calipers.... are fitted on which car?
I find all this brake lark confusing, sorry!
Old 22-01-2007, 17:24
R33 skyline? Just a guess
I think the 296mm brakes I linked to uses R33 GTS skyline calipers. You could use S14 or Z32 calipers but anything larger than 280mm than they need to be offset with brackets.
Old 22-01-2007, 17:28
RichardK's Avatar
Forum Administrator
Ok I'm getting this now, lol!
I need:
R33 Front rotors modified for S12 hubs Pair 296mm SnS
R32/R33 Caliper mounting kit to R30/31/910/S12 Pair including bolts
Pair Skyline R33 Calipers
And once I get hold of all those bits, I have everything I need?
if you got the discs the same size as the s14 ones, but those that take bells, i could get the bells made up. deamon tweaks list them.
Old 22-01-2007, 17:30
If you were to go to the hassle of making bells then get 310mm discs.
Old 22-01-2007, 17:31
RichardK's Avatar
Forum Administrator
what is a bell?
If they are just modified discs a machine shop could remachine the centres to bolt to the S12 hub.
