Old 30-01-2007, 19:40
sparkey sparkey is offline
sparkey is an unknown quantity at this point
Default 2 pin clip, what is it?
i took off the 2 pin clips that go to the injectors, and i came across another 2 pin clip, which has a white wire and a black wire, and it leads to somewhere under the inlet manifold, does anyone know what this wire is?
it comes from the same part of the loom as the injector wires
dont hate speed bumps, they make ladys boobies jiggle!
Old 30-01-2007, 20:12
detonation sensor
Old 30-01-2007, 20:25
i found that the wire from the loom leading to the flying lead was broken, what would this effect?
my gal has been mis-firing badly and wont idle very well, could this have something to do with it?
Old 30-01-2007, 20:30
The det sensor is a grey multiplug that isnt used on the ca18et, i thought you was refering to a plug like the injectors use?
Old 30-01-2007, 21:02
ok, i got 4 injector plugs ( 2 pin ), i got a sensor on the side of the throttle body,another sensor mounted on the inlet manifold ( i think, also a 2 pin ) there is a 3 pin plug between piston 2 and 3 that is not used, there is a grey multiplug which is used, there is 4 grounding pionts for the injectors, and then this lonely connector that is roughly in the same position as the 3 pin that is between piston 2 and 3.
this wire was connected but had frayed, and i followed the wire to which it is connected and it lead me to just above the starter solenoid and just below the inlet manifold.
Old 30-01-2007, 21:03
sorry adz, yeah, it is the same plug type as the injectors, and i is positioned on the loom between piston 2/3.
Old 30-01-2007, 21:14
there is an unused plug there, cant remember if its for the Auto or air con
nothing will happen if the det sensor is disconnected as long as it doesn't earth out, if it does it will retard the timing by 5 deg
Old 30-01-2007, 22:18
im getting confused by this already, can you take a picture mate and post it up? thatll help no end
Old 31-01-2007, 13:16
yes it is used, if you leave it unplugged the timing gets retarded 5deg. there is another similar plug that's not used, that I havn't traced
Old 31-01-2007, 13:30
i have already chopped the clip off, as it had frayed , but i have reconnecteed these 2 wires together as they were,
as for posting a picture, i have not got the authority at work to place pictures on here, bit of a pain.
i have decided that to get the car running proper, i would need alot of money,
which i dont have, and a growing nipper to bleed me dry.
i am listing the car on ebay in a weeks time, but if anyone is interested in a 'spares or repair ' jobby then please let me know before this.
