dump valve maybe
cant see why that would make a difference at what speed im doing??? it idles fine anything below 60mph and my DV is a baily twin piston gp1.
Ive had this on my et and det. Have you got any exhasut blows or as tim says a dump valve fitted. Sometimes a faulty or wrong specced dump valve can cause the problem.
Give the old girl a good old service mate and check sensor plug contacts, boost hoses are all good and tight ,Also listen for hissing around the inlet at idle too(vaccum leak)
Sounds to me like a vacuum leak.
Throttle position sensor.
but all those would also make it not idle when at a junction, in normal driving it idles fine, its ONLY when the car is moving at more than 60+mph and i slip it into neutral. the only think i can think of is the amount of air being pushed into the front of the car at speed is forcing to air into the intake.
