Hi 30psi,
That's correct for the o2 sensor and the trottle body positioner. An innovate wbo2 will be used in time. A trottle positioner will be a diy adjustable resistance. But are the temperature measuring devices so bad? For the air and the motor temp? The not lineair curve can be programmed. And the maf and knock sensor seams to me (with some electronic adjustments) suitable. But you have reasons to expect the setup will not work now (make some adjustments in hard- and software) or will not work for ever? Thanks in advance, Frank.
New in town !
you could use a throttle position sensor from a 200sx as its potentiometer
you would need some sort of crank sensor (toothed wheel off the bottom pulley?) does the megga squirt use coil packs? if not some modding of the dizzy would have to be done does the MS use the MAS sensor or MAP sensor? surly the MAP sensor is the way to go cant see why it wouldn't work
http://insightbookingsolutions.co.uk Last edited by wacomuk; 01-02-2007 at 23:21. |
look at VEMS for a much more complete solution
Thanks for the advice boys.
I will have a look at Vems. I concidering using an EDIS-4 with toothwheel. I will have a look at the yunkjards soon. The potentiometer will be from a old audiomixer, placed in a waterproof housing. I will place a picture as it's finished. Low budget and homemade brew. It will look awfull, but I don't care.CU, Frank.
New in town !
