  #33
Old 13-02-2007, 23:11
Originally Posted by 124
I thought I might add that in the Vlsd the V stands for viscous. Viscous diffs are basically a single open diff with some friction plates that heat up a fluid which then engages the other half but only if it gets hot enough. This system works well if used for an extended period of time or if warmed up before use (eg small burnout) but generally, when driving around normally it wont do anything if you try to drift straight up. So it is a cheap alternative to a proper lsd but its like anything you get what you pay for.
Your mistaken I'm afraid.
They don't have that effect, in fact the opposite effect. Go and jack up a VLSD equipped car and you will struggle to turn the wheel on its own.
If someone was to pratt around trying to drift all day then the viscous unit warms up. Its an energy absorber. Once its hot a worn unit won't have much resistance anymore. Just like butter.
Its a damn good modification. Its not geared towards drifting. If you want drift then spend £700 on a Nismo GT pro diff.
