Old 13-02-2006, 11:00
Default Engine bays
All prices excluding vat
Head gasket set £107.27: A104207F2E
Turbo gasket £16.48: 1444526E00
Inlet maifold gasket £8.41: 14035-D5700
Exhaust manifold gasket £4.17 each :14036-02E00
Ehaust manifold studs £1.15 each : 08261-03010
Exhaust manifold nuts £0.94p each : 08912-84010
Timing belt £24.10p : 13028-D0185
Rear subframe bushes £42.05 each : 55466-04F10
Crank woodruff key £1.17p each : 00926-51900
Crankshaft oil seal £3.50p each : 13510-88G00
Camshaft oil seal £4.30p each : 13042-D0101
Water pump gasket £3.12p each : 21014-D5701
Rear spring cup rubbers £10.20p each : 55038-01P00
Rear Arm to Subframe Inside Bolts (flat side on thread) £8.71 each: 55216
Feel free to add anymore
Old 13-02-2006, 18:49
the cam belt, is that a genuine item , coz i got mine for less than a tenner
Old 13-02-2006, 19:49
Yes these are all nissan part numbers and prices as stated in the title
Old 13-02-2006, 20:21
gripo's Avatar
gripo gripo is offline
is it as sexy as my engine bay??????
Old 13-02-2006, 20:27
Probably better than yours Least my standard s12 radiator fits
Old 13-02-2006, 21:17
gripo's Avatar
i will hold you to that. it better be!!! my standard one fits too. just too close to the intercooler pipe for my liking and too close to my mahoooosive intercooler! will post pics once its sorted out, hopefully soon. what turbo you running?
Old 13-02-2006, 21:22
mines better
Old 13-02-2006, 21:38
gripo's Avatar
thats cheating!!! ca18det!!! i dunno!!! fair play. what bhp you pumping out? i am so tempted to just shove a det head on mine. i have a 200sx bottom end. I will one day i am sure. just want to see how much bhp i can get out of this et head first. just got my 65mm throttle body back off my dad. welded up and ready to go on
Old 13-02-2006, 21:41
Will be better than that when the new engiens in with its goodies
Old 13-02-2006, 21:42
only reason i went det was because my et blew its head gasket for a 3rd time due to a cowboy lying about skimming the head and also he wrecked my et wiring loom. I like the et engine
it should be around 300-350bhp for our s12 day at Rockingham circuit
