Old 26-03-2007, 20:55
Magoo Magoo is offline
Unhappy Hole in Volvo Intercooler ???????????
look at this picture of my T5 Intercooler:
http://links.pictures.aol.com/pic?id...5Fd3Ig=&size=l
Should there be a hole here, when I flushed it out water was coming out of it. would this mean that boost pressure would also escape????????
Old 26-03-2007, 21:00
if its leaking water, it will leak air mate.
Old 26-03-2007, 21:03
When the Volvo intercoolers come they have a plate across there held on by rivets. So you could try riveting it up? Maybe with a blob of silicone under it first?
Old 26-03-2007, 21:06
Unhappy
Would a little plate welded on cause any problems created by the heat?????????????
Old 26-03-2007, 21:17
should b ok.
Old 26-03-2007, 21:25
sweet will get that sorted
Old 27-03-2007, 11:24
my old volvo intercooler had plastic end tanks which wouldnt be able to welded
Old 27-03-2007, 11:58
Epoxy Resin should do it then?
Old 27-03-2007, 15:52
dont see why not but not sure what pressure it could hold tho. would be worth a try
Old 27-03-2007, 20:31
Unhappy
I think mine is metal, but not so sure now you brought it up will have to check and find an appropriate fix
