Old 07-04-2007, 01:55
Magoo Magoo is offline
Red face Dump Valve Fitting
just about to fit a T5 intercooler, have a bailey dump valve and T piece to go with it.
When removing the original Turbo to Inlet pipe what happens to the small pipe in the middle?
When I fit the Dump Valve where do the little vacuum pipes go from there?
Old 07-04-2007, 09:27
you need to keep the small pipe on thecrossover pipe and just t into a vaccum pipe for the top of the dump valve ie:between the fuel pressure reg.
Old 08-04-2007, 21:14
Talking
where does the small pipe from the crossover pipe plumb too?
Old 08-04-2007, 22:10
big pipe and small pipe as you can see on top.
hope this helps.
Old 11-04-2007, 20:58
Talking
have you got a dump in there somewhere?
Old 12-04-2007, 00:27
Think he's trying to say dump valves are gay and you shouldnt have one ...
But no, he's showing you where the idle pipe connects to as you asked
Old 12-04-2007, 00:31
i have the cozzie intercooler, so my dump valve is on that, and the vacum is tee-ed into the vac pipe that goes to the fuel reg.
Old 12-04-2007, 20:27
dump valves do actually do a job , people with proper power use them, it stops the turbo shart snapping in half when you change gear, obviously not many people use real mans boost , not enough to need a blow off valve.
Old 12-04-2007, 21:06
Smile
cheers guys, getting more and more information everyday to get this thing built and down to JAE.
Keep up the good work
Old 12-04-2007, 21:46
hey, it also allows the turbo to continue spinning when changing gears, else you get a little turbo stall. it dont make much difference i know, but it does make some, and thats worth it in my poor old car.
