Old 12-04-2007, 15:31
Default bonjour
hello everyone im nick ,thought i better say hello to every one
iv got a 1985 s12 and 87 s12 as a drift build
Old 12-04-2007, 18:11
Got any pics? what mods have you done/planning?
Welcome to the club
Old 12-04-2007, 23:30
Welcome!
You have some good taste
Old 13-04-2007, 11:30
http://i85.photobucket.com/albums/k68/ajw_06/-3.jpg
http://i85.photobucket.com/albums/k68/ajw_06/-5.jpg
http://i85.photobucket.com/albums/k68/ajw_06/-8.jpg
http://i85.photobucket.com/albums/k6...edengine-1.jpg
im going to be using the red one at the moment it pretty standard it got a 3" stainess system,bleed valve ,baily m'sport dv and a welded diff
i got a cossie 4x4 ic to go on when i get round to making the pipe work up, and then im thinking on building a nice weld in cage ,
what other mods would you lot recommend
cheers nick
Old 13-04-2007, 13:27
James H's Avatar
James H James H is offline
Thats one tidy engine bay in the red silvia!
Old 13-04-2007, 13:37
Depends what your goals & what your budget is, i would recommend a set of AVO springs and KYB shocks as a good place to start. Then maybe a T25 turbo and a welded diff if you wanna drift.
Old 13-04-2007, 19:17
diffs already done ,drifting is my main intrest at the momont ,how much would a t25 tuby cost and would i needto modifie anything to fit it
Old 13-04-2007, 19:40
T25 should bolt straight on. keep your eye on the for sale section or check out http://www.sxoc.co.uk/vbb. Should be able to get your hand on one for about £100 if you look in the right places. Also try your local breakers yard for any s13s as there standard kit on them.
in fact found this just now, http://www.sxoc.co.uk/vbb/showthread.php?t=280158
Old 14-04-2007, 07:43
Originally Posted by slimreaper View Post
T25 should bolt straight on......
The outlet pipe on a T25 comes out at a different angle to the T2 so you'd have to modify the pipe to the IC slightly but it's not rocket science, probably need to buy a sillicone hose with a different bend in it. Someone will pipe up if I'm wrong but you may need the turbo elbow from the S13 T25 as well and the oil and water feeds shouldn't cause you to many issues but if you want to be really bling you can always get some braided jobbies from driftworks
Old 25-04-2007, 00:33
welcome to s12oc. Your red mk2 looks pretty decent
