Old 05-04-2007, 09:23
James
this winter all the works been done in my single garage at home, but in previous years ive used the workshop at work at nights and weekends.
Pukka
yeah it would be good to catch up at some point mate.
this season is a late start for me, and will mostly be at sprint or hillclimb circuits rather than race circuits as im getting married in august and am struggling with time and cash, but next year will be a full-on campaign again
will post up which meets im doing when the cars finished and entries are confirmed.
Old 11-04-2007, 12:59
ext wastegate screamer pipe finished and exited thru the lower wing just above the sill
Old 17-04-2007, 18:25
IC pipe work coming along.
chopped the stub off my new shiny IC Gulp
just need the new stub TIGged back on and a plate over the old hole
Old 17-04-2007, 18:37
Looks all good but I bet in hindsight you think it was a bad idea using an external wastegate. Looks like it was a bit of a pain in the rearend to sort especially with the screamer piping.
I like the retro cutting of the IC.
Old 18-04-2007, 10:09
yep total pain in the arse!! i dont want it exhausting under the car or in the engine bay so its turned out to be a pain. i just hope it does spike less and control better than a normal actuator. if it doesnt itll come off as its extra weight and complications. if it does work, thn i may look at rejoining it back to the main exhaust if its too loud or unreliable
Old 18-04-2007, 10:10
Is it adjustable?
Old 18-04-2007, 10:50
as far as i know, but have a boost solenoid valve connected to ecu. with the two tappings on the wastegate, im right in thinking that the one holds the valve shut whilst the other goes to the boost solenoid?
Old 18-04-2007, 11:05
Can't remember to be honest. Sometimes you only used one of the tube's and it depends on the type of controller.
Old 18-04-2007, 13:21
with the profec b, you use 2 parrallel openings on the solenoid with external wastegate, but with an actuator, you use opening on front and one of the sides.
Old 18-04-2007, 15:30
not ready to pipe it up yet but will ask you guys advice when id do cheers
just taken the IC to be welded, should be a few days as they are flat out and i dont want to use someone else i dont know
