Old 26-04-2007, 23:30
i have the bottom nipple on the wastegate plumbed directly to my turbo compressor housing and i use a 15psi wastegate spring. I dont use a boost controller at all and i just run 15psi
I have a 7psi spring that i had installed before with my blitz boost controller. that was plumbed in exactly as you described. using the top nipple as a spring gain. Best bet is to run it without anything on the top of the wastegate at all and plant your foot slowly and check that your spring rate is what you asked for as if its from ebay you can sometimes be entered into the spring lucky dip
Whys the wastegate leaking. Did you get a machined washer that sits inside the wastegate flange on the wastegate and a gasket togobetween the two flanges?
