Old 28-04-2007, 22:27
graememk graememk is offline
graememk is an unknown quantity at this point
Default s12 in a lotus 7 kit car
well the s12 is in the mk indy replica lotus 7 and the engine running megasquirt but i have a problem, the cars been on the rollers today and its running full fuel but it goes lean above 3800rpm the injecters cant supply enough fuel with the amount of boost (8psi), what do i need to do, as far as i can see its either fit new injectors, change the fuel reg or up the pump, what have others done that run high bhp please
graeme
Old 28-04-2007, 23:08
8psi is not far from standard, it wouldnt think it should lean out at that boost, mines running 10psi, and as far as i know its not lean (hasnt gone bang in past 8 years ive owned it, although mine has had a small pinking prob of late, i think its more down to type of fuel and timming slightly off, seems to have gotten better since putting in 97RON fuel.
people on here have been running 15psi ish on std fuel, only thing most have is the uprated fuel pressure reg and fuel pump.
im sure they will post soon if im wrong.
hope this helps some, if the RR you used was any good, they should have had some ideas as to the cause and cure.
Old 28-04-2007, 23:15
we only used the rr as a bench mark as they dont know anything about megasquirt, the injectors were just fully open and the engine still ran lean so its a deff a fuel shortage prob, where can i get a different pressure reg from or off ? if changing it do i need to change the rail ?
Old 28-04-2007, 23:57
i'd say fuel pressure reg or pump, i ran 18psi on a t25 on the std ecu with no probs.
Old 29-04-2007, 01:45
what fuel pump has been fitted to the car?
Old 29-04-2007, 10:38
the fuel reg in part of the rail so its a new rail or cut up yours and find an adjustable reg to plumb in
Old 29-04-2007, 11:59
i would check this first. The standard fuel reg is non adjustable, the fuel pressure rises accordance with the inlet manifold pressure, if the fuel reg isn't receiving correct manifold pressure the fuel pressure will be affected (lower)(idle fuel pressure is 32psi from memory) check for cracked pipes
the standard reg could be past its best, try a FSE adjustable fuel reg or something similar
silviagod has had good results will the cheap jap ebay ones
are you the guy off locostbuilders??
Old 29-04-2007, 14:52
useing the original fuel pump,dont know what psi it is.
Old 29-04-2007, 14:59
using the original silvia pump or kitcar pump?
Old 29-04-2007, 16:54
silvia pump, silvia reg and rail and injectors.
