Old 30-04-2007, 00:34
Default Anyone dismantled these driveshafts?
I'm wondering if anyone has dismantled these type of CV joint housings. I can only think they need hacking open?
Old 30-04-2007, 07:52
yeah mart, you have to cut them around the outer casing, they are the early mk1's, turbo mikes one i borrowed was like that.
Old 30-04-2007, 09:07
But arent they then buggered afterwards?
Did you literally just cur 1mm behind the rubber boot, so it only damages the ring, or further over so its actually on the CV housing?
Old 08-05-2007, 11:58
Shaun?
Old 08-05-2007, 11:59
no mart, you only cut around so it just breaks through .just a bit further back than that lip by the rubber mart.
Old 08-05-2007, 12:02
I assume I'd have to buy a new rubber boot and ring to re-use it then?
Old 08-05-2007, 12:12
the one that i took apart, was the one that i put the s13 end onto, then the other 1 like that, i gound the 8mm off, but i gave the 8mm one back to turbomike and used a mk2 shaft thats cos it was machined for the snap ring in the lathe and the mk2 one is'nt seal like the shitty mk1's,lol.
Old 08-05-2007, 12:17
I wanted to inspect the shaft inside. The design of the early shafts is actually carried on from the 280zx and 910 series. They were running UJ's before that and obviously didnt think people would ever want to take them apart until in about 1986 someone used their brain and decided on the later version.
I saw a fekked early driveshaft and the spider assembly wasn't held in with circlips, the end of the driveshaft in 3 places was curled in to keep it secure. That was the hub end of the shaft, but I wonder if its the same on the diff end.
Old 08-05-2007, 12:19
diff end did have a circlip on it on the mk1 shafts that i had and you could get the spider off.
Old 08-05-2007, 12:27
Ok cheers shaun. I'll wait until I get a doner shaft then.
