Old 05-05-2007, 23:13
bigtim's Avatar
bigtim bigtim is offline
Default helicoil kits
Two of the manifold studs are coming out and i need to sort them so does anyone know what size helicoil kits i need and the best place to get them so i can have ago at repairing them.
Old 06-05-2007, 02:05
Most likey to be M10x1.25 proving they are original studs. Some replacement studs were M10x1.5 so remove them and measure the thread pitch.
Old 08-05-2007, 18:07
shifter shifter is offline
S12oc Newbie
shifter is an unknown quantity at this point
hallo.
I did it last month it doesn't matter what kit helicoils you order as long it is a m10. what does mater is te tap you use. the treat isn't 1.5 that i know for sure. but i did all the studs and order 6 new and used 1.5 studs.
peter
Old 08-05-2007, 19:16
bigtim's Avatar
Thought you get the tap in the kits,so is it m10x1.25 kit then
Old 09-05-2007, 12:06
what about helicoil kit for the 2 bolts of motor mount under intake manifold?
Old 09-05-2007, 12:07
Thats probably M10x1.5
Old 09-05-2007, 17:38
S12oc Newbie
I think it is 1.25 indeed but before you take it all of torqeu the rest of the bolts to fac. specs. then you can see if you need to do more then those 2.
just a tip.
peter
