There should be a grey plug which plugs into the top. You can't see it in your pic its hidden behind a pipe. But on the top of the stem of the air regulator is where it connects to.
Sounds like they're both shut, but because you have adjusted your idle to be correct at cold idle, it will be too fast when hot. If it was adjusted to the correct speed when hot, then you would suffer low idle when cold like Robs. However if it was working, then when its cold the air regulator is open to increase the rpm by up to 700rpm from experience. I've only had one that worked really well. It seems they seize after a while. The way they work is fairly simple. There is a bimetallic strip which should open it up when cold. When the engine is started there is a current passed into the bimetallic strip, so when the strip is heating up it shuts the valve.
I've just bought an 89 BB Turbo and it has exactly the same problem. I have taken off the Air reg and noticed that the slide inside does move when pushed with a screwdriver though. I suppose the only remedy is to swop it with another known good one. I havent got my manual, does anyone know were the feed comes from ie ecu or relay ?
The feed is from the eccu timed same as fuel pump. Its a current device and draws about 250mA @12v but probably a continuity test is good enough to show that the heater element is working (continuity should exist) I have fitted a unit off a scrap yard car which is better than I had but I've been unable to find a new one?
I've heard of carb/intake cleaner freeing these up as its the carbon deposits that make then seeze.
They are a bugger for locking up though
