Got the paint finished finally... waiting for the ENEM reground camshaft and new oil pump to arrive, should be here today, so the engine will be assembled and fitted by the end of next week, mapping is June 22nd and first drifting event june 29th.
Some new pictures are on my blog, see below.. and a tester here, if it works.. Conk. ]
Website: http://www.racing-green.com Blog (with 180zx build pictures) http://racing-green.blogspot.com/ |
Looks good. Those wheels need to come out another inch on the rear to make it look hard
would need to change the 70mm porsche 924 rear studs for 100mm ones! will do it if we get time... we already have spacers for it....!
Mike
Cant you use bolt on spacers?
Yepp... we could ahve done that, but we had these studs knocking around and access to waterjet for cutting spacers...
We are running 14mm studs now, so if we go for bolt ons, then we will probably need to make them ourselves.... so 100mm studs would be quicker, easier and probably cheaper. Later, Conk
