Old 18-06-2007, 22:34
front what i can gather no it needs to be shorterned about 50mm i think
Old 18-06-2007, 23:12
S14 box is same length as S13, I had to cut the hole in the floor back on my car about 3 inches to get the S14 one in. I used the original gearbox mount, and it bolted up to the original position but needs the holes opening out a little.
What gearbox did you have previously? ie mk1 or mk2?
If its the mk1, cut the dust shield off of the prop and fit in in the gearbox. Then you may have to redrill the floor for the centre bearing bracket. The mk2 props dont have the dust shield on them as this is incorporated on the box.
You might be lucky and find the centre bearing is direct bolt up so you can then just get the rear half shortened.
Old 19-06-2007, 01:00
i had a mk1, what i was looking at doing was keeping the rear shaft that goes onto the diff standard and just ajusting the front shaft from the box
Old 19-06-2007, 01:04
Best to see what its like once the box is in place.
On my Datsun the standard prop with a mk1 style front end is only about 5mm too long despite the shifter being 3" back
Old 19-06-2007, 01:24
o rite so you managed to shunt the unit 5mm back with out modifing the props
Old 19-06-2007, 01:34
I could probably get it in there with brute force but this would be bad news on the gearbox oil seal. It needs to be pretty reasonable to account for subframe and engine movements.
Gonna have a go at shortening the prop myself as I have 2 spare anyway. Once I'm happy with its length then I will get a custom one made.
Old 19-06-2007, 07:49
yea, will just have to play a game of trial and error when i have the motor built , might try and look into any other nissans that run the same sort of prop shafts and see if any are a little shorter. If not send it to the prop shaft clinic
Old 19-06-2007, 18:36
Most of the custom props we have done are 100mm splined telescopic. This makes them extremely universal,doesnt stress gearbox and diff seals and easier to fit and remove
