the sr20's usually seem to sit right at the bulkhead(looking at a mates 180sx) so i dont think beating the bulkhead would be much of a option?
I hear the bolt pattern is different for the gearbox..
i thought that they sat pretty close to the firewall , i suppose i could always cut it out and weld some sort of boxy type thing to gain some clearance(like they do on old mini's when fitting webbers, as far as the gearbox go's the only difference that i know between pulsar sr20's and s14 ones is the block construction in that the pulsar block is all alloy , i can't see why they would cast a different block for just one engine type surely it would'nt be cost effective, but then again i could be wrong
i had a ca18et engine from a silvia and tried to put it in my ca18et bluebird(fwd) and only about 3 of the gearbox bolts lined up
if the worst comes to the worst i could always get a bell housing adapter made up , but i'm gonna try and cram in all the 4wd stuff in there if i can, at the moment i'm just exploring all of my different options
The SR20 will only fit in a car with the original drive configuration that it came out of due to engine mounts and gearbox. A GTI R eninge will not go in a Primera even though they are both transverse mounted because of the 4 wheel drive transfer box and gearbox, and the engine mounts are different on both from the rear wheel drive SR20.
sounds like some major silvia surgery comeing up then
But you will have a job putting a RWD box onto an transverse engine, incompatible. Why not try and get an S14 engine instead? easy to get hold of. |
