Old 14-08-2007, 10:19
So I still have trouble.
Yes 12psi will be my goal, it sufficent for me .
I'll check my car to find something later.
Some hints for reflexion: I'm at 3rd gear around 2000rpm, stabilize my cruises. When i went full throttle, it goes 1B and drop to 0.6 (spike appeared) but when i reached 0.6, when i upshifted, no problem it went to 0.6 and maintained the boost until 5800/6000 rpm.
I tested in 4th gear same thing, 2000 rpm, full throttle, spike appeared too
According to me: perhaps I have a leak hided, the spring of MBC is not enough hard,...
Thaks for all
Old 14-08-2007, 16:34
i think your actuator is week. The actuator cant hold the waste gate back against exhaust gas pressure causing it to open and reducing boost.
i would buy a adjustable actuator from turbo technics (around £80) fit it and remove your bleed valve
http://www.turbotechnics.com/docs/co...t2actuator.htm
Old 14-08-2007, 19:28
Problem solved!
It was the screw that was enough screwed.
No drop at all! Incredible!
Thanks fo all supply
