Old 02-02-2006, 10:28
Default What MK s12 do I have?
Can someone give me a quick guide on the different s12's available.
What defines a MKI and MKII? I have a 1989 s12 so am presuming this is a MKII. The MKII is not the s13 I gather?
Also I am after a wing, will it matter if I choose MKI or MKII?
Are most MKI and MKII parts interchangable?
Thanks
Old 02-02-2006, 11:28
Mk2 is what ya have. Nearly everything is interchangeable. You will be able to use the different wing but the bump strips are different. There may be a small difference in how the sidelights are held as well
Old 02-02-2006, 14:38
so an MKII wing would be ideal if possible, but the MKI is not impossible to fit either just a little more tidying required.
Mechanically how do they differ? Gearbox? Engine? Mounting points?
Is there any newer nissan engines that would bolt straight in? Or would I need a mount kit?
Thanks for your reply
Old 02-02-2006, 15:06
Mk1 has a different gearbox and prop. Smaller bumpers and flatter bonnet.
The turbo oil feed is taken from a different place.
The S13 200sx engine is a direct replacement.
