Old 20-08-2007, 16:25
mr_turbo's Avatar
mr_turbo mr_turbo is offline
i got a t28 on mine is a lil laggy if ur cruising along then decide to toe it but does give a good old kick on boost n mines been runing 12psi for a while now with ease is rather simple to fit jst need a s13 elbow and a boost elbow n ur away i had to also kit 2 lugs off of the gearbox for it to fit aswell!! well worth the labour thou :d
Old 20-08-2007, 20:09
i run a garret gt28r on my det motor and found it really good but should be even better at 300bhp
Old 22-08-2007, 11:06
mr_turbo's Avatar
arh 4got to mention i also had to make a nipple for the actuator pipe where the bleed valve goes as the t28 didnt have one as they are on the boost pipe after the turbo!
i used a brake line nipple and drilled a hole in the elbow after the turbo works a treat lol
Old 23-08-2007, 21:32
duncan's Avatar
duncan duncan is offline
i used to have a t25 running 15psi. it lasted for a while and pick up was great but i drove flat out one hot day after forgetting to put the dipstick back in! the cloud of smoke was kinda a tell tale sign. i still have it and a t28 with oil seal gone just not sure to get them rebuilt or exchange for new turbo from someone like turbo technics
