Old 22-08-2007, 23:12
Raz987 Raz987 is offline
Raz987 is on a distinguished road
Default Step by step guide to ignition timing?
Can anyone lay it out straight for me, I have access to a timing gun but haven't done it for at least ten years.
Have done a search but couldn't find anything useful.
Cheers, Raz
I've got an S13 and a Scimitar SS1 race car... what's wrong with me????
Old 23-08-2007, 00:57
Very simple, visually the same principle as your S13 on the bottom pulley:
Undo a 10mm bolt locking the distributor and move it to the left to retard it or to the right to advance it.
15 deg's BTDC
Old 23-08-2007, 19:45
323ian 323ian is offline
Is 15degrees BTDC the stock setting please?
Old 23-08-2007, 20:08
yes 15
Old 23-08-2007, 20:09
Thanks mate.
Old 10-11-2010, 19:03
mr.bishi mr.bishi is offline
mr.bishi is an unknown quantity at this point
Hey all.....sorry for the threadromancy,but i have a quick timing related question.
I picked up an s12 auto at the weekend and it was having running problems....not helped by the dizzy being loose!
Obviously,i need to set the timing,so....Is it set using no1 or no4 on firing stroke? I've had a look in the manual,but it didn't seem to say...
Cheers..
Old 10-11-2010, 20:08
You'd typically use no.1 but 4 will do the same
Old 10-11-2010, 21:13
Actually,that has just dawned on me that it's the same thing.....The reason i ask is,i cannot see my timing mark under the strobe using no1 but i can using no4 and it's vexed me a little. The strobe is flashing too
Unless it was picking up a signal from another lead i guess....
Thanks anyway.
Old 10-11-2010, 21:48
Check resistance of each wire.
Old 11-11-2010, 14:53
What value am i looking for? 30k rings a bell?
