Old 03-09-2007, 20:57
mr_turbo's Avatar
mr_turbo mr_turbo is offline
Default Lowering springs
my springs are 40mm lowered at the front n less at the rear round!i dont know wot make they are all i knw is that there nlue my mates is about a inch lower then mine n his are pink n have puma spring 092 or something writen on them any ideas where i can get some or ne lower then mine?
Old 04-09-2007, 09:41
http://www.nissansilvia.co.uk/vbb/sh...ht=coil+spring
Have a nose at this thread, Not sure if they can sort you out with the fronts or not. Also if the rear end hasn't been slotted you might find that lowering it any more makes it handle like a bag of ferrets because of the amount of neggy camber you'll end up with. On the Avo -35 jobbies we've got around 3 degs!
Old 04-09-2007, 10:33
The negative camber will help with cornering grip if there is average body roll. The front will slide out before the rear unless its power oversteer.
zero front camber and lots of neg rear camber will cause this. Its best to increase the front camber and then reduce the rear a little.
Easier said then done though
Old 04-09-2007, 10:38
...ergo it will handle like a bag of ferrets
Old 04-09-2007, 10:47
I had 4 deg's on the rear of mine and never had issues except when trying to launch.
The front end does a lot more work than the rear, and thats where the first attention should be paid.
Wouldn't say it will handle like a bag of ferrets, the camber actually helps keep the rear in place around the bends.
Old 04-09-2007, 10:54
Ok then
Old 04-09-2007, 19:52
the whole car needs a setup done on it.None of it is right
Old 07-09-2007, 15:09
mr_turbo's Avatar
so there not many places that do springs then lol
