Old 13-09-2007, 10:11
graememk graememk is offline
graememk is an unknown quantity at this point
Default injectors
having probs with my injectors on the ca12et, are there any others that fit or can you buy them ?
they need to be high impedance as the standard ones are low impedance
many thanks
graeme
Old 13-09-2007, 11:22
High impedance does narrow it down somewhat.
I had some high imp 550cc's which are double the flow of the S12's. They were from an RX7.
Search on ebay US, OZ and UK for rx7 injectors. They can fit with minor mods. Also some of them have irregular plugs which are hard to find.
195500-1370 is the part code BUT they come in both high and low imp's. The high imp is redish/purple and the low imp is light brown/tan
195500-1350's are 460cc but you'd need to check the resistance, feed type and plug type.
S12 injectors are 270cc, so you'd need to do a remap to suit larger ones.
of course you could fit resistors to the original injectors
Old 13-09-2007, 11:32
when you say they will fit but need modification what do you mean by this ?
Old 13-09-2007, 11:37
Well the injectors don't fit properly in the cups nor do the original fuel lines fit to them because they're 2mm larger. Hose can be squeezed into place though.
The cups can be machine sanded or something to get the injectors to fit properly.
I test fitted them like this without the cup:
