Old 08-10-2007, 19:13
323ian 323ian is offline
Think i will have to have a go this way first before i pull the whole of the subframe out. Just think that they new ones will take a press to push them in though, those alloy ones may have been slightly smaller than the stock ones.
Old 09-10-2007, 12:05
duncan's Avatar
duncan duncan is offline
another way of doing it would be to get them made in halves in nylon or polyurethane. would be much easier to fit. probably best to fit a steel sleve in the centre too. rich has something like this done. he has a thread on suspension bushings on here somewhere
Old 09-10-2007, 22:26
Thanks for your help, only way i can think of doing this effectively is to drop the subframe down a bit and get some heat on the casing to help make it a bit easier to fit them, i have already got a set of stock bushes to go back in.
Old 09-10-2007, 22:58
smoker's Avatar
smoker smoker is offline
I dropped my subframe as low as i could on the bolts and used a chisel between the subframe mount hole and the outer part of the bush to get the old bush out. To push in the new bush i used a long bolt and two 1/4 inch plates to pull in the bush. Might not be the correct method but it worked
Old 09-10-2007, 23:01
Thanks for that mate, thats a very good idea which i think i will try.
Old 12-10-2007, 13:20
they were made as an interference fit, they need hammering in
Old 12-10-2007, 13:33
Yeah they need hammering in really firking hard
