Old 01-11-2007, 17:23
docertabum's Avatar
docertabum docertabum is offline
S12oc Newbie
docertabum is an unknown quantity at this point
yes you can put a gauge in the fuel line.
I did it... the pressure of fuel was 2.7-2.8kPa in idle situation... normally it should be somewhere around 2kPa I think....
Old 01-11-2007, 17:28
not sure about kpa, but it should be around 37 to 45lbs.
Old 01-11-2007, 22:06
old-and-rusty's Avatar
For the FJ engine fuel pressure check, the s12 manual states:
at idle approx 206 kPa (or 2.06 bar or 2.1 kg/cm2 or 30 psi)
the moment throttle pedal is fully depressed approx 255 kPa (or 2.55 bar or 2.6 kg/cm2 or 37 psi).
Hope that gives you enough different pressures to go for ....LOL....
Regards,
Ian.
Old 01-11-2007, 22:14
lol , i was being idle and quoting the ca18et pressure, i could not make it out of the chair to get the manual.
Old 02-11-2007, 11:21
My last post makes me sound like a real "boffin" ...LOL......
The manual is on the bookshelf at the side of my PC, so I don`t even have to get up to reach it. If I had to get off my backside, it might be a different story .
Regards,
Ian.
