Old 05-12-2007, 15:45
mr_turbo's Avatar
mr_turbo mr_turbo is offline
Default s13 injectors
Right i have my s1 injectors and i need to make up a fuel rail as the s12 rail is half the size as the s13 so im going to try to modifiy it just wondered if anyone had doneit?
aslo ive bolted the s13 throttle body on as it is 5mm bigger in diameter and im pretty sure the throttle postion senser is the same so should bolt on.
has anyone modifed the s13 penlum to fit aswell? if so how lol ....
cheers
Old 06-12-2007, 07:48
S13 throttle fits straight on but you will probably have to remove some material from the manifold as the hole there will be smaller.
Old 06-12-2007, 07:51
mr_turbo's Avatar
yer doing that today ive lined it up last nite going to get the die grinder out this morning hehe!
its the injectors casueing me the hassle need to find a way off mounting them i mit modifiey the s13 fuel rail to fit
