Old 13-12-2007, 16:45
Dazz Dazz is offline
Default Intercooler and dump valve fitted.
Hi guys, i did a search and found a few bits of advice but i just want to check a few things.
Ive just finished fitting my intercooler to the S12 with a T2, i used a Golf 20v turbo wing mount and mounted it by the rad with a good cold air feed, i used a cosworth 2inch - 2.5inch boost hose from the turbo to a 2.5inch tube around 6inches long then to a bit of silicone coupling to the bottem of the cooler, from the top outlet of the cooler i managed to use the standard hard pipe with a 2.5inch T-piece for a bailey dv26 dumpvalve then fitted to the throttle bodie, for the dv vac line i plumbed it in using the black vac pipe that runs across the top of the bulk head under the vin plate? i assume thats ok as i read most use the one from the fuel reg.
I also fitted a boost controller, mechanical one its a ball type or something, and i just set it half way, so im unsure of the psi, now the car drives great, i seam to have really strong top end power, strange as but if i drive hard the wheels spin all the way to the redline where as befour it wasnt as strong and the power dropped off a little earlier, the dump valve lets off buts not really that loud, so do you recommend i bin it? as i seam to have lost the chatter noise from the waste gate.
Thanks and sorry for the essay, just thought the more info the better.
Dazz
Old 13-12-2007, 17:00
i really think dump valves are not needed unless you are running very high boost, they stop the turbo stalling and twisting the shaft, they also cause uneven idle and a moment of overfueling on a car with and air flow meter.
Old 13-12-2007, 17:12
Oscar's Avatar
Oscar Oscar is offline
ive found in the past, that the nearer to the inlet the louder they are post up a pic of the intercooler matey
Old 13-12-2007, 17:42
I'll post a pic when theres some daylight, i think the DV is a twin piston? maybe a bit stiff, worked fine on the evo but i was running 1.6bar, so im guessing the baby t2 doesnt push that much.
Thanks
Old 13-12-2007, 20:29
mines a bailey twin piston dump valve, and tbh my T2 dont make it sound as loud as it prolly would with a T25
Old 14-12-2007, 18:06
Hi again, no pics yet, but i tried a forge dump valve from a friends RST and its alot louder, so i assume that the spring is weaker on the piston, not really worried about the DV so i think i'll run without.
