Old 12-02-2006, 08:39
nissanman's Avatar
nissanman nissanman is offline
S12oc Newbie
nissanman is an unknown quantity at this point
Default Finally got my CA18ET dynoed!
Hey guys,
Finally got the CA dynoed
Ill get my dyno sheet up asap. But here are my results.
1st Run-109.8rwkw
2nd Run-109.6rwkw
3rd Run-109.2rwkw
Im pretty happy with that seeing as im only running 10psi.
Also i have a bad exhaust leak from my manifold to turbo, which the dyno place said is taking abit of power away and making AFR go a bit crazy up top.
Also my pod was considered a HAI, hot air intake lol.
A 3.8lt VX Holden Commodore with extractors, exhaust, pod and some other little bits got 106rwkw So i was happy my 1.8lt bet that, but overall i got the best out the under 2.0lt class.
I will aim for about 125rkw at mayb 13psi when all is well. And new pod is on..lol
Cheers!
AUS12 Australian S12's |||| www.aus12.bb2.org
Old 12-02-2006, 10:07
Do you have a torque figure at an exact rpm point? i will convert it to our countries recognised bhp
Old 12-02-2006, 12:28
Just convert the KW straight to BHP which is 1.341.
If you convert max torque it will only give BHP at that point which isn't necessarily where max power is.
So his max power is 147bhp which I guess is at the wheels
Old 12-02-2006, 14:30
cheers martin
