Old 13-01-2008, 19:37
zxocmars zxocmars is offline
Default How do I...
open the bonnet when the cable doesn't work???
MK1 S12
Old 13-01-2008, 19:43
Dr Silvia's Avatar
can you get to the cable end? the simplest way i found was with a pair of pliers if just the nipple has come off..
Old 13-01-2008, 19:50
hi
If you mean by the pull lever, the cable still seems to be attached to this, but there is no resistance when pulled.
I'll try to get the cable itself and see if that helps.
Old 13-01-2008, 23:05
without actually going outside and checking, cant you put your hand up under the bumber behind the grill and open it by hand manually.
Old 13-01-2008, 23:11
Have you tried a crow bar?
Old 14-01-2008, 00:11
Dr Silvia's Avatar
hmm
ok first check that the outer sleeve hasnt pulled thru its retaining hole, if its still as should be by the release lever then you're going to have to reach round like umpkin said
Old 14-01-2008, 10:53
put your hand through the hole under the bumper and bent the cover covering the lock mechanism out of the way. Then get a pair of pliers and pull on the cable!
BTW the mkI and MKII cables/locks are different
Old 14-01-2008, 23:09
old-and-rusty's Avatar
I know on a Mk1 you can actually reach up under the bumper and feel for the bonnet release. If I remember correctly you should be able to push the lever, that the cable is linked, to by hand. Can`t remember with it pushes up or down. But I had to do this when my cable snapped. It is a bit fiddly and you need to be almost double jointed .
Regards,
Ian.
Old 14-01-2008, 23:28
thanks guys
I'll try this next time I see her.
Old 15-01-2008, 08:47
Hope we haven't given a secret away to a Twoc'er!
