Old 03-02-2008, 18:45
jakezx's Avatar
jakezx jakezx is offline
jakezx is an unknown quantity at this point
Default overboost
just fited a t25 on mk2 and it just boost freely so i can only quarter throtle and will boost to 10psi but if go anymore and it will go to 20psi datdrift has had a look but we came up with no ideas have bost controller have not fitted it dont if it will help also i need to change the plugs.
any eles had problems
Old 03-02-2008, 18:55
Dr Silvia's Avatar
check the wastegate hasnt siezed or that the actuator hose isnt split or such like.
Old 11-02-2008, 18:36
jakezx's Avatar
checked all of them and all is fine all i can think is change the the wastgate to a t2 one would that help?
Old 11-02-2008, 18:40
Dr Silvia's Avatar
its worth a try.. if thats not it the only other possibility i can think of is that there's something wrong with the wastegate inside the exhaust.. like its blocked with something, or if sourced from some less reputable companies undersized..
Also, check your boost guage doesn't bear the logo from 'the fast and the furious' or something equally as dubious. i've seen these lie before
Old 11-02-2008, 18:42
check for kinks in pipes or check that there isn't a blockage down any of your actuator or compresser housing pipes, i had a pipe that had perished and collapsed inside, or another way of raising the boost was to use a t piece and small jets, perhaps this could of been done already,
