Old 21-02-2008, 18:56
Default Water lines from T2 cancelled, dangerous?
I'd like to run without watercooled, can i drive my car? (I have a turbo timer, for no cocking the oil)
If someone have some link for braided ones which can be shipped to France, it'll be apprecious.
Old 22-02-2008, 11:23
old-and-rusty's Avatar
There have been a couple of previous threads about this.
I seem to remember Pukkasilvia saying that you don`t really need the water cooling, as when the water is hot, it`s not really doing much to cool the turbo anyway .
I guess as long as your oil is changed regularly and there are no blockages in the oil supply pipe you should be okay. I know that a few production cars don`t have water cooling for the turbo.
Hope this helps .
Regards,
Ian.
Old 22-02-2008, 11:48
Thanks mate
Old 22-02-2008, 13:38
Its not essential, but is deemed essential on a ball bearing turbo, which the S12 wouldn't have had
Old 22-02-2008, 14:12
theres no waterways at all on my turbonetics t76 bb tubby. i'am sat hear polishing it, i must be sad.
Old 22-02-2008, 14:17
Polish your knob like us younguns do instead
Garrett harp on about cooling their turbo's. I can't see how much effect cooling a turbo with 90 deg water does but if Garrett recommend it for their turbo's then thats probably what you got to do.
Do you spin your turbo up? I think its great how they can even spin up by blowing in to them
Old 22-02-2008, 14:41
i can't mart, my wrists have gone , i know that garratt do recomend water cooling as the t34 i had was water cooled and they don't guarantee them unless you use water, i ant spun it up though. is there any updates on your engine yet ?
Old 22-02-2008, 14:59
There was a bit of an issue ordering the piston rings which took time to resolve. Having to use a hybrid of Mazda 323 and CA18DE rings. Using Totalseal gapless rings.
I've not been exactly pro-active on much though. Just not motivated one bit.
Old 22-02-2008, 19:48
I have said before that the water lines on a t25/8 are not essential but i have seen you do track days which is very stressfull for any car so really you should fit them ,
if your on increased boost on a t2 its going to run extremely hot and your performance and turbo life will suffer.
The water lines are partly there to reduce heat transfer from the exhaust housing to the compressor housing
They also aim to reduce the temperature of the oil circulating the turbo so that it lubricates more efficiently
Old 23-02-2008, 07:45
I ditched mine off my spare s12 that i was running and it worked fine, it wasn't untill the turbo started burning gallons of oil that i couldn't drive it..... I came up with an idea a couple of days later and hammered the oil feed flat so no oil could get to the turbo got a 2 months extra use and the turbo started siezing after about 1 mile
