sorry for the delay in replying, thanks for the advise.
I was looking today, the coil i have now cleaned up but still no spark i have checked that fuel is coming through. It is pumping in to the chambers i think there was a lot of pressure behind the fuel when i undid the hose. I was wonder how the is setup do these engines have a crank position sensor ???? if so any pics, if not what do they use. any other ideas would also be a great help. anyone one got a spare ignition coil plugs leads and distributor laying around that all work for sale??????????? |
There is a Crank angle sensor, but not sure that would be your problem
I'm no expert by any means, but if the CAS was out woudl it not still spark, but out of sequence? Might have a spare one somewhere |
i figured that if it was broke it wouldn't tell anything to spark???
I'll dig around for a spare in the week
i have a spare coil up the loft, i spotted it last night.
how much would you like for the coil???? does it definitely work. anyone got a pic of a position angle sensor so i know exactly what i'm looking for.
Thanks again for the help |
The crank angle sensor is built into the dizzy itself. If you know how to run the Self Diagnosis process on the s12, you will get an error code No.11, if the CAS is faulty. Hope this helps .Regards, Ian.
its in the dizzy??? how could i check this??? or should i change the distributor for one we know works. Anyone got one for sale?
Hiya,
Yep the CAS is in the dizzy. The control unit for the self diagnosis proceedure is behind the trim panel on the passenger side footwell. Remove the trim panel and you will see the control unit, if I remember correctly, you will have to remove the mounting screws for the unit and turn it round (as the lamps that display the fault codes are facing away from you) - but leave the harness connected. There is also a diagnosis mode selector switch, which you will have to turn with a screwdriver. If you do a search on this board, there should be a thread on here that lays out the self diagnosis prceedure. Hope this helps .Or if you know someone else with an s12, I guess you could just try their dizzy on your car, to see if that solves the problem. Let us know how you get on .Regards, Ian.
