When i fitted my det on the mounts i cut the little locater off my nismo mounts
Just rotate the mount 90 deg's, the dimple is supposed to sit in the same slot that the bolt goes into. I would also recommend not tightening them up until you got the engine in place as you get a degree of flexibility from where they can move up and down in the slot
Allright, ill see what can be done, when i get back home.
Thou i would have a prob with tightening the mount, once the subframe is back in the car. Basicly theres no room to reach that bolt, i guess i would need some sort of a smart wrench, that i dont have
if you have the fj20 mounts, could you measure the thickness of them in mm please as i was told they where about 47mm with the engine on them, thanks.
This image shows visually how the dimple should sit
who's engine is that mart ?
Nothing to do with me, its just a pic I found.
Thanks for the help 30psi. Got the mounts in today, everything looks fine for now
