right, i'am wanting to fit me 300zxtt front calipers,now i've never bled brakes before, i've bled a few womens gashes
,so i do i go about it, do i just follow the bleedin procedure out of the manual, starting at the rear, as it don't say if you are putting front calipers on follow this method, obviosley the frontswith be full of air,so do i bleed them from the back first.
Follow the manual but in general Bleed the fronts first starting with the drivers side as it is closest to the pot.Finish on the passenger rear. You will need to get one of your nippers to sit in the seat and pump the pedal and keep an eye on the reservoir level at the same time. When you lock the nipple off once the fluid is constant the brake pedal needs to be still pushed down.
cheers matey.
