i just wana say a big thanks to shaun for his assistance this morning! And as for my ecu it does fuk all, it just does same as shauns lol!
mine is a mk1, if i unplug the AFM, nothing happens, it idles the same, if i try and rev it in that state, it just coughs and splutters and revs a very little, when i plug it back in it tries to stall, but normally recovers (has stalled before when ive done it)
so in all it dont sound much different to mine, but mine does goive a fault code for the AFM
Obvious thing to of done would be to fit a known working afm to it, Ie borrow shauns afm off his car to do a test.
Have you worked through that list i wrote you to try 2 threads ago? save me repeating myself as im lazy tonight
i tried all the list, not much change, shauns afm died, when we upplugged it. So a difrent behavior to mine...
did you plug it into yours though
no it started to piss it down, so we called it a day.
well tried the red nissan temp sensor, which blew 2 fuses, and tried the blue 1, but the plug guides are diffrent so gota trim with mr stanley, then i can try it! Quick question, the 3 relays by the battery, black, green, black, fuelling? Wat does each individual one do?
