Old 12-04-2008, 14:01
Paul Smith Paul Smith is offline
Paul Smith is an unknown quantity at this point
Default she is running again - dump valve question
Hi
some of you may have read my last thread where the car wouldn't fire but she is working again now thanks to a member it was a faulty distributor after all.
Ok question i want to add a dump valve she has had one in the past and she has a T pipe from the intercooler but which breather/pressure hose is best to plug the one from the dump valve in to?
Thanks
Paul
Old 12-04-2008, 14:24
there is a fitting that has a blank on it up on the bulkhead behind the clutch master cylinder. If not that one you can tee off any other vacuum line of the right size. It really doesnt matter, As long as you can feel vacuum there at idle you know its a goodun.
Old 12-04-2008, 16:37
Thanks for that, don't suppose you have a pic of the one you've used just so i get it right.
cheers paul
Old 12-04-2008, 16:50
silviagod's Avatar
you can see it on this pic. Bugger it didn't work!
try this link: http://www.silviagod.pwp.blueyonder.co.uk/Teeings.JPG
sorted
