Old 24-05-2008, 20:50
RichardK's Avatar
RichardK RichardK is offline
Forum Administrator
Default Removing the diff
Can someone just remind me how to remove my diff without dropping the rear axle?
I need to pop a manual diff back in rather than the auto one but not sure how to remove the diff as when I fitted the current one I had the entire rear axle in my workshop lol
Old 24-05-2008, 21:24
Beany-s12's Avatar
i just unbolted the outer cv joints from the shaft and levered one of them up so i could slide it all across and drop one side down!
i did have a 2 post ramp to do it on though which made life alot easier
Old 25-05-2008, 19:07
RichardK's Avatar
Forum Administrator
So unbolt the drive shafts at the wheel end, then pop them off at the diff end, undo diff mounting bolts and wiggle it all out?
That about right?
Old 26-05-2008, 01:19
Beany-s12's Avatar
i unbolted them at wheel end but left the shafts in the diff and dropped it all out together! was a bit tight though
Old 26-05-2008, 11:35
There's a big bracket in the way on each arm. You have to be a man and squeeze the shafts in tight to clear it. Or you can be a woofter and remove the bracket, which seems to bolt to the bottom of the shock if i remember correctly.
Old 26-05-2008, 18:12
Beany-s12's Avatar
i must be a man then Grrrrr
Old 26-05-2008, 19:28
RichardK's Avatar
Forum Administrator
No, having a big dick makes you a man. I'm a hell of a man
As for the diff, tomorrow will tell. I'll make a how to afterwards. I have a bad back tho so won't be overly easy anyway grrr!
Old 26-05-2008, 19:29
Originally Posted by RichardK View Post
No, being a big dick makes you a man. I'm a hell of a man
Old 27-05-2008, 07:56
[quote=RichardK;26120]No, having a big dick makes you a man. I'm a hell of a man QUOTE]
Depends where the dick is . . . (ie sitting on it doesn't count)
