Old 08-06-2008, 21:37
zxocmars zxocmars is offline
Default Car won't start
Started the car this morning and she fired straight off
Changed the exhaust for a 2.5 SS straight thru, and now won't fire.
Car tried to fire, but then cut out, and now it just won't fire at all.
I have fuel, and I have spark.
I have been advised that there is a possibility that the cambelt has jumped, screwing up all the timing.
Any advice on how to correctly check this please?
TIA
Old 08-06-2008, 22:12
RichardK's Avatar
RichardK RichardK is offline
Forum Administrator
Sounds rather odd. 30PSI is the man to tell you how to check the cam belt. I'll be amazed if it has jumped though to be honest.
It actually sounds more as if it's flooded? Mind does that sometimes, if it doesn't fire first time, it floods itself.
When you fitted the exhaust, did you disrupt any air pipes? E.g. air intake, etc.
Old 08-06-2008, 22:18
It hasn't jumped a tooth.
Chances are, as RK said it's flooded.
Get in to the right hand boot compartment and pull out the tray. Under there is 2 plugs. Disconnect the 4 wired flat plug to disconnect the fuel pump. Then try to start it and hopefully it will clean itself out a bit and then reconnect the pump.
Old 09-06-2008, 00:43
thanks for the responses
One side of the belt does appear to be a little slack though
If it was flooded, would leaving it for a while allow time to evaporate, and thus it would start later. ???
I tried again half hour later and it still wouldn't fire
I will try the suggestion of 30PSI, but the pump seems to be working, Can you explinan this a little more please?
Old 09-06-2008, 09:03
You don't want the pump to work, it will continue to flood the engine, so disconnect it to turn it off, but this has to be done from inside the boot.
Old 09-06-2008, 14:29
or take out the fuel pump fuse and try drying the plugs
Old 09-06-2008, 14:51
Taking out the fuel pump fuse will stop it sparking though. You need to try to burn off the old fuel so best just to disconnect the pump.
My mate flooded his so bad the only way to get it started was to tow it and get the engine spinning at 3k
Old 10-06-2008, 22:02
RichardK's Avatar
Forum Administrator
Take out the plugs, dry them with kitchen paper, put them back in. Turn the engine over with the fuel pump disconnected.
I can cut my fuel pump off with one of the immobilisers but otherwise do as Martin said and unplug it.
S12's are brilliant at flooding themselves!!
Old 10-06-2008, 22:06
when mine does that, i just take the water temp sensor off straight away and it fires up with a couple of turns.
Old 16-06-2008, 19:07
Dazmans12's Avatar
Banned
Default wont start
Hi
Some good tips here for you. Here's a cuople more for you to check over, If fuel pump is on its way out then may not be enough pressure to fine spray the fuel into the cyls, so could just be dribbling in via injectors & flooding engine. Try getting a pressure check for the fuel, eaisy to do, happened to one of my s12s, however I was able to run, so long as it was on a flat road, any need for power & she would splutter & cut out. My S13's Fuel regualor, when it packed up, did the same & just wouldn't start, but I ve no heard of
S12 fuel regualors going.
You can dig out the ECU,(is located in the side pannel of the passenger footwell) & run a self diagnostic, which might point you in the right direction. newer ECU's have the fault codes written on the top of the box.
if the AFL(Air flow metre) is knackered, or has become disconnnected.
As has been said, if any of the air intake pipes, turbo to plenum chamber is disconected then def wont start.
Just a few for you to look into.
Good luck
daz
