Old 15-06-2008, 19:07
Paul Smith Paul Smith is offline
Paul Smith is an unknown quantity at this point
went to fit it and have broken the end of the copper pipe. Bloody typical.
Has anyone got one of these in good nick they are willing to part with? Or can make one on short notice? I don't really wanna buy a flaring kit for one pipe?
Old 26-06-2008, 19:13
Ok finely got the copper pipe. fitted the pipe which is a brilliant fit.
Have now come across yet another problem. I am trying to bleed this clutch but every time the pedal goes down it stops and you have to pull it back up, is that normal?
If or am i doing it wrong or any suggestions.
Thanks again for your help so far
Paul
Old 27-06-2008, 09:49
There should be a return spring at the top of the pedal, has it come off/broken?
Old 27-06-2008, 16:25
did the pedal stop when you are trying to bleed the system as it will do this. If not the most probably the spring at the top of the pedal sort of like a bow shape
Old 27-06-2008, 17:08
kennyboy's Avatar
kennyboy kennyboy is offline
Default Return spring
Return spring has broken on mine and i just drilled the pedal and fitted a spring at the top been like that for years now lol, work though just a bit noisey and the pedal sits lower than the others but not by much.
Old 30-06-2008, 15:58
yes it was doing this whilst trying to bleed the system, so its normal then. Will it do it all the way through the bleeding process or only untill all the air is gone?
I don't think the spring has gone because it does return sometimes and was returning before i tried bleeding the clutch.
Old 30-06-2008, 17:40
The clutch should return to "Normal" if there's nothing holding it to the floor.
Old 25-07-2008, 18:30
ok got an update, i have got the new copper pipe and fitted it i have bled the clutch and yet she will still not go in to gear whilst running?
What could it be?
the clutch release bearing seized if so how do i loosen it?
or maybe the clutch slave isn't moving far enough although it looks good to me?
help again
thanks
paul
