Old 01-08-2008, 20:10
paulsilv's Avatar
paulsilv paulsilv is offline
Thanks Sharas,
I'm usually quite handy a figuring things out but this looks like a dashboard unscrewing event which I'm not inclined to do.
Old 03-08-2008, 16:44
mine dont have the adjustment, but to get to where is should be you only need to take off the column couling, tis 3/4 screws under the column, and then once the bottom is off you should be able to get access to the adjustment part.
Old 03-08-2008, 22:29
wacomuk's Avatar
wacomuk wacomuk is offline
UK spec cars didn't get adjustment US and JAP cars did
The only Silvia i have seen with steering adjustment is Silviagods car
Old 03-08-2008, 22:31
Dr Silvia's Avatar
ok the first thing you'll be wanting to do is take the column trim off to inspect the column itself; its no good having a lever if the shaft itself wont move!
Haven't got the manual to hand but theres one joint in the adjustable shaft shave a feel about for it! Not yet seen a uk silvia with an adjustable column though..
You take the column trim off with a long philips drivertheres 3-4 screws on the underside.
wdit: forums should lock if someone is already postinga reply!
Old 03-08-2008, 22:39
ChEsTeR ChEsTeR is offline
All european LHD silvia i have seen had a steereing colum adjustment
Old 03-08-2008, 23:41
Dr Silvia's Avatar
Lucky!!!
Old 04-08-2008, 14:24
paulsilv's Avatar
Will get a pic up so everyone can see what it looks like,
WOW I might have a rare beast if its adjustable
Or then again it might just be me.
