Old 10-09-2008, 15:54
rob turbo's Avatar
Default Dash light bulb replacement
can anyone advise me on how to do this,... i need to know how to take the clocks out to change the bulbs... looks like a dash removal...?? cant see nearly half the dash a night now
whats the best way..
cheers..
Old 10-09-2008, 16:17
its quite straight forward tbh, each side of the clocks are 2 little tinted plastic strips (where the fog light warning light is) take them off carfully, under there is 2 screws, then the surround comes out, tis clipped in the back (this is the whole plastic bit covering the clocks, then you will see 4 screws around the clocks, undo them and gently pull it forward, i found unclipping the wires a bit tough the first time.
bulbs on mine were normal small push in, rated 5w i think, dont quote me on that.
hope this is clear and helps.
Old 11-09-2008, 18:49
rob turbo's Avatar
cheers dude, many thanks
