#19
Found this on AUS12 site that GerryB posted about were to wire in what for novices like me
---The white plug by the ECU has the wires you need for these items ONLY!! * orange wire = start signal, goes to start wire at your s12 ignition plug * black wire = goes to earth * blue/black stripe wire = goes to s12 temp guage = temp signal. These are the only ones you use from the white plug!!-- ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ---The other wires are from the plug by the Maf connector in RED -- Black / Pink stripe Fuel Pump Relay Red / Black stripe ECU Relay Red ECU Backup Power Black / Red & Blue / Red (Note: connect 2 wires to 1) Main Ignition Power Black / White stripe ECU Power Brown (to O2 sensor) O2 Sensor Power Any 12v switched source Yellow / Red stripe (or use the Diode to each Coil pack as suggested and take to the Silvia tacho) Tachometer signal
