Old 02-12-2008, 01:57
Default Tips for changing discs?
First time i'll change the F&R discs on my car.
Any special tools for removing them? Nothing on FSM.
Any tips?
Thanks
Old 02-12-2008, 12:59
Easy on the rear. Easy on the front too, its just messy due to the wheel bearing which you should repack wth grease and also not over tighten
Old 02-12-2008, 13:03
Thanks mate!
How check bearings with the wheel on?
Old 02-12-2008, 13:30
The service manual explains how to check the resistance of the bearing, but you did it with the wheel off
Old 03-12-2008, 01:31
about the nut for front disc I have a 32mm tool, is it good? Seems a littre free.
Old 03-12-2008, 10:08
Its done up with very little torque. Very low. Something like 10nm, but you need to check the service manual
Old 03-12-2008, 22:10
if you can get one..gumble...grumble
Old 03-12-2008, 23:12
25nm i think mart, i'll check, still not a lot though
Old 04-12-2008, 09:14
Well its done by measuring the resistance in the bearing. You need a newton meter to measure it, but what by I don't know.
I just did it until the hub started to get a little tight to turn and then loosened it off a few deg's
