Old 08-12-2008, 16:03
Ronin's Avatar
Ronin Ronin is offline
Silvia Driver
Default High idle/running rich
After to many hours to count chasing down bad earths my Silvia is finaly running again but the idle is high and the mixture a bit on the rich side. I've tried adjusting the idle with the idle adjustment screw but this has made no differance is there any way to adjust the mixture then set the idle? At the moment it idles at 1000rpm.
Old 08-12-2008, 16:23
mine has started idling around 1000rpm, i thought it could be the chilly weather! or your throttle cable may need a little slack adding, or the way your throttle cable is routed can cause silly probs like this! other than that check the throttle position sensor, give it a clean, actually give all your sensors the once over! oh & clean the afm by your air filter, inside & out
other than that i have'nt a clue
