Old 23-12-2008, 10:13
Originally Posted by duncan View Post
thanks for the info lads. i was looking at emerald ecu's after getting a catalogue with retro cars or something. rewiring the engine doesn't bother me cos I'll be changing a few things anyway. lookin for value for money and ease of use. i would like to map it myself but it's something i have never done. having said that i never did anything with turbo cars until i got my s12 and now theres not much standard left on the car.
nobody is going to show me how to map a car as they will be doing themselves out of a job so theres only one way i'll learn anything.
how does the bottom pulley work out with the position sensor? is there one for a det available?
hows the black legend coming on jackiefan?
Emerald gets rave reviews from everyone I've spoken to about it, admittedly I know know anything about mapping ecu's.
Going to be running Omex in mine when it comes to it but that's just because I got a good deal on one
The Crank angle sensor wheel thingy from Omex is just a disk with a small 10-15mm hole in the middle of it, I guess the Idea is you then get a machine shop to match it to the OD of the crank pulley then tack it on. You then rig up the actual sensor (?halls device?) off the front of the block using mecano or something. Its a one size fits all solution although I'm sure there are some clever sods out there that have found other ways around it.
The MKI is coming on, all be it rather slowly (I just don't get the time to work on it). Got mostly S13 parts for the front end sorted and painted, all the front bushes are done. Just need to get the manual rack back from my old man so I can get it rolling again then it's off to get a cage fabbed up (when I can find someone to do it for my for sensible money). I'll update the project thread as soon as I've got it to a point I'm happy with.
