Old 11-02-2009, 18:02
martin.herwitson's Avatar
Default Uprated transmission mounts?
Has anyone found a supplier for uprated engine or G/Box mounts? Mine are all a bit soggy, allowing the box to hit underfloor sometimes....Cheers.
Old 11-02-2009, 18:10
i used ford escort / transit mounts from rally design, about £10 each,all that you have to do is make a 4mm thick steal plate bolted across the steal bracket to the block with a hole in the center, cos the transit mounts are solid rubber mount with a thread top and bottom in the center, these do allow for a big turbo ie: mounted underneath as cutting the std mount weakens it.
Old 12-02-2009, 08:53
I did the same on my last S12, the latest one I've used Cusco S13 mounts (loads stiffer, but rather pricey).
Used an S13 bracket on the near side, but on the offside I made an adaptor plate (as above) and had to very slightly mod the mount for it to fit. Not done anything with the gearbox mount as yet.
Can sort pics if you are interested etc.
Old 12-02-2009, 20:14
if i remember correctly i used and still do a nismo s13 one and can be got from apex performance for about £55 i think
